Pentair Intellivalve Actuator
deelands
11
Dallas
Hey all, Happy Thanksgiving!
I noticed this leak today at this actuator and it seems to be leaking at the rusty screw. How would y’all go about this without buying a new replacement? Ive been looking for replacement parts online but I can’t find anything. Any help on troubleshooting a leak and how to find replacement pieces (screws / o-rings) that would fit this actuator would be appreciated!
Jimrahbe
31,451
Bedford, TX
dee,
Just to be clear... No water runs through the actuator. The actuator is just moving the valve right below it.
It looks like the seals on your valve need to be replaced.
Something like this.. https://www.amazon.com/sspa/click?ie=UTF8&spc=MTo3NzkyODA0NzgxMjYwODYzOjE2NjkzMzQzMTU6c3BfYXRmOjIwMDAxMjA0NDg3Mzk3MTo6MDo6&url=/ATIE-PoolSupplyTown-Diverter-Valve-Replacement/dp/B07MXSV5S8/ref=sr_1_2_sspa?keywords=jandy+valve+repair+kit&qid=1669334315&sr=8-2-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&psc=1&smid=A2P38V7C7755KW
Not sure the link above is for your specific valve, just posted so you knew what was available.
Reactions: deelands
ajw22
47,207
Northern NJ
Pentair Intellichlor IC-60
Water leaks past the O ring on the valve stem that gets up to the actuator.
You need a closer look at the valve under the actuator to determine if it is a Pentair or Jandy valve to get the correct O ring kit.
deelands
11
Dallas
dee,
Thanks for teaching me something!
deelands
11
Dallas
Thank you, I’ll get in there and take a closer look. Is there a way to measure the o-ring so i can make sure I buy the correct repair kit?
ajw22
47,207
Northern NJ
You need to remove the four screws holding the actuator onto the valve stem and lift off the actuator.
Once you identify the valve manufacturer there will just be one size O ring for it.
Reactions: deelands
