- Feb 17, 2022
- 383
- Plaster
- Pentair Intellichlor IC-40
I have a Pentair Intelliflo VSF pump for my filter that is connected to an easy touch 8 control center. It does communicate and turns on and off as well as controls the pump speed without issue. However, the display on the pump is blank and most of the lights on the control pad are lit up. When i turn power off to the pump via the breaker and let it shut down completely then turn it back on, the display reads with the display not active message. The easy touch shows "normal" as the status.
I have a second Intelliflo for my features (same model as filter) that is connected to the easy touch as well and its display reads the standard "display not Active" message. Which leads me to think its my filter pump that has issues.
Since everything works, should I be concerned about the display? A pic of the display is below.
