Pentair IntelliFlo leaking Water/Air at seam of Control Panel
ShaunG
2
Dallas Texas
I am in N. Texas and we had our freeze last week but this pump ran 24x7. Limped along maybe 50% primed because there is a leak at the seam of the display panel (just above electrical plug). I've indicted in the pic exactly where its leaking. Was leaking water initially and now just air because I cant get it to prime at all now. Any ideas? Leslie Pool guys said there should not be water anywhere near there and there is no deal there that could be the cause.
Jimrahbe
20,958
Bedford, TX
Shaun,
Pool water can not get into the pump's control panel... What can happen is that rain or condensation can get into the display area.
Show us a larger pic... Are you sure that something near by does not have a leak and is spraying or falling on the pump???
ShaunG
2
Dallas Texas
Hi Jim,
You were correct. I was able to locate the leak at bottom of the pump and it was running up the side. So now I assume its probably going to need a new seal and gasket?
Thanks for your help, I appreciate it!
Shaun
