I have a year old Intelliconnect setup, running a single speed filter pump and Polaris booster.
Tonight I got home from work and noticed the pump wasn’t running, opened the control box and saw the red fault light on the #1 relay (filter pump) I’ve seen it red in the past but it always work.
All breakers were closed on the house panel and pool sub-panel, I powered cycled everything at the panel to try and reset the system, no dice.
I then opened up the high voltage cover and measured 240V across all Line 1 and Line 2 terminals.
Called Pentair, they couldn’t explain WHAT causes the fault light so I know where to look next.
Any leads appreciated!
