I am not a pool guy - I am an automation programmer. I have a client with an Intellicenter and 2 10 circuit expansion boards. For the most part the integration is working as it should. All devices on the main board are being controlled and reporting properly. The problem I am having is with the expansion boards - the control system is only seeing 1 auxiliary board, and when a command is sent to control any of the circuits on the one board, it is also controlling the circuit on the second aux board. This would lead me to believe that there has to be some sort of addressing that needs to be done, and that both boards currently have the same address.
1) First question is - are the aux boards addressed in some way?
2) If so - how?
The pool guy who did the programming is not understanding the issue as he tells me the circuits work fine - but he is activating them manually at the board, so they should work independently then
2) If so - how?
