Pentair intellibrite 5G LED 12V switching options
fldrummer79
7
IND HBR BCH, FL
Pentair Intellichlor IC-40
Hello, I'm currently installing an easy touch 4 relay automation panel with screen logic 2 and I plan on controlling a new intellibrite 12V LED light with it. There is a light switch on my patio that used to control the old light. My question is, can I hook up both the light switch and the easy touch? It may be more convenient to use a light switch vs. a phone app to turn the light on/off depending on the situation.
Thanks
Jimrahbe
20,191
Bedford, TX
79,
Doubtful...
You'd need to wire it as a three way switch and use a 2-speed pump style relay in the EasyTouch. This would most likely involve running a new wire between the old light switch and the EasyTouch.
As a side note, I use my PC and ScreenLogic about 95% of the time. It works better has better displays and programming is easier. I rarely use the phone app.
