Hi all...
I have a 24k gallon in ground plaster pool with a Nautilus DE filter and a 1.5 HP single speed Hayward pump (7yrs old), a Hayward heating system, and an auxiliary pump that I never use anymore. The other day the main pump started smoking and basically burnt itself out. I'm now looking at replacing the entire system since I find myself replacing the filters in the Nautilus every two years and going to a Sand filter using either silica sand (ZeoSand) or the new glass media (Maytronics Activate Glass Filter Media). However, my question here is which pump to go with... I have had two different recommendations from two different local pool stores (no surprise there).
One recommended a Hayward Maxflo VS pump with a Hayward S244T Pro Series Top Mount Sand (24in. Tank) In Ground Pool Filter using Maytronics Activate Glass Filter Media.
The other recommended a Pentair Inteliflo VS pump with a Pentair 145322 - (22" tank) Sand Dollar SD60 Top Mount Sand Filter using silica sand.
I'm hoping that someone can point me in the right direction based on any experiences you might have. I have attached a couple of pictures of my current setup. Thanks!
