Pentair IC40 "SUPER CHLORINATION" vs. 100% output setting
brucehenson
79
Taylors/SC
Hello again.
Tested this morning and FC is starting off low (FC 4.6) and I am expecting swimmers and sunshine today. I turned my IC40 up to 100% thinking that I would need to remember to turn it down later. The manual is not clear about what "SUPER CHLORINATION" actually does. Based on what I've read on this forum the IC40 does not have variable output just a percentage of run time.
To the question...is "SUPER CHLORINATION" simply 100% setting with a timer that will return to the percentage that I have selected once the timer expires?
Bruce
Jimrahbe
15,070
Bedford, TX
Bruce,
Yes... :mrgreen: Super chlorination just automatically shuts off...
That said, we never recommend using it, unless you just want to use up your cell faster...
We recommend just adding some Liquid Chlorine.. It is faster and does not use up the chlorine generation capability of the cell..
Almost all U.S. cells only use a timed based output control, not just the IC40..
Reactions: jackrogue
brucehenson
79
Taylors/SC
Thanks Jim and Matt,
I have some liquid chlorine, just have never opened it, I guess it’s about time. I’ll turn the cell back down and consult Pool Math as to how much I need.
brucehenson
79
Taylors/SC
Thanks to everyone for responding so quickly. I have returned my cell to 60% and added 40 ounces of 10% liquid chlorine which should result in 1.2 ppm increase per Pool Math.
What would I do without this awesome resource?
You guys are the best,
Bruce
brucehenson
79
Taylors/SC
Boy, Pool Math was dead on. FC is now 6.0 up 1.4 ppm. I didn't measure the Liquid Chlorine out, roughly 1/3 of the gallon jug.
Pool Math predicted 1.2 ppm increase at 40 fluid ounces for my 27,000 gallon pool. The variable's are in the dosage, testing procedure, and pool volume. It is remarkable to get that close!
