pentair ic40 showing too high of a salt reading
aaron_w_o
148
ottawa, ontario, canada
Pentair Intellichlor IC-20
My easy touch says my salt level is 4100ppm.
I've had the water tested twice at pool stores and it comes back around 3300.
I also tested it myself using the TFP test kit and it was like 3000.
does this mean there is a bad sensor somewhere? or is the value on the easytouch/ic40 known to be off? I would think the pool software uses this salt value to decide how to run the SWG?
mknauss
44,843
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
That level of error is more than normal. Pentair SWCG runs independently of the ET, it just sends a salt reading at startup and every 12 hours if left running that long.
Is the SWCG happy? Green light for salt? Generating chlorine? If so, I would not worry about it.
