Pentair freeze protection mode -- priming error
platon20
101
DFW/Texas
Every time my freeze protection switches from spa to pool, the pump shuts down with the error "dry priming"
It only affects the pool circuit, spa runs fine the entire time without the same error.
However, if I press the reset button on the pump, it starts immediately drawing in water from the pool fine and starts running again.
I'm thinking the freeze protection mode isn't running at high enough RPMs to draw water in? When I manually reset the pump I use the highest RPM available which is 3500 but I don't know what the RPMs are in freeze protection mode.
mknauss
36,503
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
The pumps should shut off while the valves are moving. You can set that in your ET programming.
You should also consider reducing the RPM for priming. Use 3000 rpm. Even 2500 rpm unless you have issues with priming.
