Pentair error code
Jimrahbe
23,487
Bedford, TX
Jeff,
Welcome to TFP... A Great resource for all your pool questions... :shark:
What specific Pentair VS pump do you have? Do you have an automation system tied to the pump?
The info below is from the Superflo manual.. You can try it, and it certainly can't hurt.
If an alarm is triggered the drive’s LCD screen will display the fault code text and the SuperFlo® VS Variable
Speed Pump will stop running. Disconnect power to the pump and wait until the keypad LEDs have all turned
off. At this point, reconnect power to the pump. If the error has not cleared then proper troubleshooting will be
required. Use the error description table below to begin troubleshooting.
Thanks for posting,
