pentair easy touch 4 wiring installation
Fred82
4
Connecticut
Hello,
I'm trying to install easy touch panel but I'm getting confused with two transformers wires If any one have a pic of wire with mire details than penal door let me know appreciate it
Jimrahbe
18,250
Bedford, TX
Hi Fred,
Pics don't help much because there are often so many wires of the same color it makes it hard to see where each wire is going..
Do you have a saltwater panel, that has a large and small transformer, or just one small transformer?
Jimrahbe
18,250
Bedford, TX
Fred,
I looked at your PM and see where you have a saltwater pool... So here is a pic that shows the large transformer (SWCG) connecting to the Pump Filter relay.. This set up is configured for 240 volts..
Notice that two wires for the 240 come from a Circuit Breaker and go to the Line side of the pump/filter relay.. Then the yellow and white wires from the SWCG transformer are connected to the Load side of the same relay. The Black and Violet wires are connected together with a wire nut.
Reactions: GDN
