Pentair 474200 Mastertemp Basic Manifold leak
apq0506
2
Houston
Hard freeze got me. Think I'd be okay just replacing the heater manifold cover. I've only had my equipment for 6 months.
ajw22
24,950
Northern NJ
Pentair Intellichlor IC-60
You may have a damaged Water Pressure Switch. Check the areas recommended for winterizing...
bashunov456
6
Houston, TX
i believe my manifold is leaking after freeze. Is it bad for me to run it until the replacement part comes (ETA July)? It works without issue, just a constant drip when the pump runs
ajw22
24,950
Northern NJ
Depends how much water you lose daily.
Why not install a heater bypass?
