Hello! I am new to the forum but have read enough to know there are really nice and knowledgeable folks here. I apologize if this is a topic posted up all too often.
I have a Pentair 160301 cartridge filter. The pool was installed a couple years ago (first pool) and we were idiots when it came to landscaping. Most of what we planted craps in the pool constantly. So...I am adept at cleaning the filters.
The last time I cleaned the filters, I noticed the drain plug had some grit in the threads and that half of the threads had been ground off. So I ordered another plug off Amazon.
This morning, I noticed a slight drip by the drain plug. I got the 7/8 wrench and tightened a bit and the top of the plug broke off from the threads. Great! Immediately turned everything off and started disassembling.
I removed the bottom of the filter shell so I could turn it over and get to the threaded portion still stuck in the shell. Luckily, I was able to remove the threads. Leslie's had a replacement (thank goodness).
Before putting the new plug in, I took a pick and cleaned out the threads in the shell as best I could. They looked a little worse for the wear. I put a few wraps of Teflon tape around the plug and some petroleum jelly on the O ring. I screwed it back in and got it reasonably tight.
After putting everything back together, the plug still drips. Argh! I grabbed my channel locks and gave it another eighth of a turn. It helped, but still dripping. I'm scared to tighten the plug too much for fear of stripping out the shell. That would be a $500+ mistake. And that's IF you can get one.
Before draining and taking this all apart again, I thought I'd ask for some expert advise. Any thoughts?
