Pentair 011018 vs 022055
jorge18
199
Miami, Fl
Hi all,
I need some help with choosing the pump for my new build. I'm torn between the 011018 and the 022055. The latter seems like overkill, but it's only about $80 more so I'm leaning that way.
What's everyone thought on the two? Is upgrading to the 022055 worth it?
Attached is the plan for my pool for reference.
ajw22
19,391
Northern NJ
You will never know the difference in operation. If you want to spend a bit more then go for it.
Jimrahbe
18,765
Bedford, TX
Jorge,
Does you pool have 2" or 3" plumbing?
It does not make sense to install a pump that needs 3" plumbing into a pool with 2" plumbing.
The 011018 is obsolete and have been replaced by the 011028.
jorge18
199
Miami, Fl
Jorge,
Jim,
The main drains are 3" and the returns are 2.5". According to my research, the 022055 will accept 3" and 2.5". Please correct me if I'm wrong.
Jimrahbe
18,765
Bedford, TX
Jorge,
You are not wrong, the pump allows you to use 3" or 2.5 " plumbing.. That size plumbing is somewhat unusual unless you have major water features. I can't see a downside as long as your plumbing is large enough.
