Peer Review on chem?
Bvill16
Active member
Mar 15, 2019
30
New York
Hi All,
I would like to get your thoughts on my chem over the last week or two since converting to SWG. I have been reading everything about TFP and think I’m close but wanted a peer review.
Test Results 06-16-2020 @ 09:05 AM
Free Chlorine: 11.5
Combined Chlorine: 0.0
pH: 7.7
Total Alkalinity: 90
Calcium Hardness: 250
CYA: 90
Salt: 3500
Temperature: 81°F
Test Results 06-14-2020 @ 11:51 AM
Free Chlorine: 9.5
pH: 7.7
CYA: 90
Salt: 3300
Temperature: 80°F
Maintenance 06-14-2020 @ 10:15 AM
Brushed
Test Results 06-12-2020 @ 12:30 PM
Free Chlorine: 9.0
pH: 7.7
Calcium Hardness: 300
CYA: 100
Salt: 3400
Temperature: 85°F
mknauss
36,977
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
Do remember that your pH tested when FC is at or above 10 ppm is not real accurate.
I assume the early tests with low FC did not bring about any cloudiness or algae in the water.
Looks good. Keep the FC up there with your 90 ppm CYA.
Bvill16
Active member
Mar 15, 2019
30
New York
Hi MK, I read that as well and my eyes are not the greatest with colors. So I am a bit worried about my pH.
The first two tests were early on when switching from pucks to the SWG (also prob why my CYA is high). No cloudiness or algae in any test or day.
Should I try and lower the CYA a bit by dilluting?
mknauss
36,977
Laughlin, NV
Fiberglass
I think you are fine on the CYA -- just have to be aware. By end of summer it will come down some due to dilution if you have any overflow events (rain) and if your filter type is sand or DE that you back flush. Please add your filter to your signature.
Bvill16
Active member
Mar 15, 2019
30
New York
Hayward cartridge and I will add it thanks.
