Paramount 004-302-4408-00 Six Port Water Valve Module wont work
sunny8088
156
Longwood, FL
All,
I installed this may be 1.5 yrs back.
1. New O ring with Lube
2. Switch on RUN
3. Cleaned the unit
4. Pressure @ 20 on Unit
Still i wont rotate the base valves.
Help
Thanks and Merry Christmas.
kadavis
In The Industry
Apr 5, 2015
1,651
tucson, arizona
Take the module out and turn over and try turning impeller and see if gears are moving on top. Also take the lid and make sure when you move the run/pause knob it turns inside
sunny8088
156
Longwood, FL
I took it out & turned the impeller , it does move gears.
Also checked the run switch & works inside.
Can I remove the module & put the cap back !! will it open up all valves together ?
sunny8088
156
Longwood, FL
All Paramount nozzles are sized and placed specifically for your
pool by Paramount. These nozzles have different sized open
ings and if removed, should be returned to the same location.
NOTE: Switching nozzle(s) location will result in poor cleaning
and could severely damage your pool equipment.
What is the meaning of same location ?
