Painted Pool
sixtz4me
Active member
Jul 4, 2010
34
Apopka, Fl
Guy's I just recently had my Marcite (worn out) pool painted with epoxy/urethane with a 15 year warranty. Now, I need some info on the chemistry parameters. Is everything the same as in TA, CH, Ph, etc, or are things going to be drastically different? I'm not having very much luck online. TIA
zea3
12,696
Houston, Texas
Your chemistry parameters should be the same as before, however if you were instructed to use specific parameters for your warranty to be valid I would go with those and keep good records of your test results.
