Turbo1Ton
- Dec 26, 2019
- 1,836
- Plaster
- Pentair Intellichlor IC-40
IntellipH is not terribly difficult to install, depending on your comfort level cutting into the pluming and reworking that. Electrically, the control unit just plugs in to the intellicenter, and the pump plugs into the control unit. So should be no need to get an electrician involved. One thing you might want to verify, I see you have the IC60 cell. I have seen posts recently stating that the IntellipH is not compatible with the IC60 salt cell. I believe that Pentair has stated that it draws too much current for the electronics in the IpH controller.
--Jeff
--Jeff
