I'm thinking about running a new return by the steps in my 15'x30' above ground oval. The existing Pentair Light/Return Combo doesn't appear to be giving me the flow and circulation I'm looking for unless I run my 1-1/2hp Hayward two speed pump on high. Even then I'm suspecting some leakage between the liner and the inside of the aluminum wall (perhaps because I didn't cutting back the foam backing around the hole). In any case, the current return location is very close to the skimmer while the steps are located at the other end of the pool.
Instead of cutting through the aluminum wall and risking ruining my liner (it's a hanging liner so not so easy to get out of the way), I was thinking of simply running the return piping up through the adjacent paver deck and over the top of the pool near the step rail, then down into the pool using rigid PVC pipe (transitioning from 1-1/2" to 3/4" just before coming up through the deck). This way I can have multiple discharges (e.g. on at the top and one at the bottom of the pool) via the same return line.
Any thoughts or suggestions?
