Outage that lay last few days, what should I do ?
Paxcou
133
NJ (shore)
Severe outage here in Jersey. Probably few days as trees have felt all over the place. What should.i do to keep the water in good condition as it is today as the filter may not work for few days ?
Donldson
5,225
NW Ohio
Keep your chlorine level above minimum and do what you can to circulate the water a couple times a day. Brushing, swimming, whatever it takes to mix up the water occasionally. The loss of filtration will not turn your pool green as long as you keep the chlorine level in check.
Good luck, stay safe!
Reactions: magiteck
