Our 1st spillover spa, a few questions w/ pic
May 13, 2013
19
Bentonville, AR
Hello, I'm a seasoned pool owner and longtime TFP member but I've never owned one with the spa option. I've searched the forums but still have a few questions for the pros reading this post...
1. How do I identify which mfg & model spa we have so I can order a cover for it?
2. We live in NW Arkansas so I'd only heat it as-needed during winter, correct?
3. Roughly how long could it take to bring it up to temp?
4. It appears to have four filters in the lower part of the shell, how often should we replace those?
It's roughly 88" in diameter and has six jets. Thx in advance for any assistance!
Jimrahbe
15,800
Bedford, TX
78,
Does this spa run off the same equipment that runs your pool? Do you normally close your pool in the winter?
The 4 "filters" just cover the suction plumbing that sucks the water out of your spa.. The filters just prevent large stuff from getting sucked in the suction pipes. If like mine you should be able to clean and reuse them over and over.
My guess it will take about half an hour to heat the spa.. But have no way to tell..
Vegas Mike
18
Las Vegas, NV
We have a spa/pool combo. The time to heat the spa depends on your heater BTU rating and the spa size. With our 400k BTU natural gas heater, the 700-gallon spa heats about a degree per minute.
