Order to add chemicals
gwtw
90
Kentucky
I need to add muriatic acid, a bag of salt, and 20 pounds of calcium to my pool. (PH is 7.8 or 8.0, salt is 2800, CH is 130, FC is 5, CC is 0). I assume that I should add the muriatic acid first. After adding the muriatic acid, how long should I wait before adding either salt or calcium? Since both salt and calcium are added by broadcasting them into the pool and don't dissolve that quickly, which one should I add first, and how long do I need to wait before adding the next one? Also, after I add calcium, how long do we need to wait before we can swim, and how long should we run the pump after adding it? I plan on adding the calcium in 5 pound batches, 12 hours apart, instead of adding all 20 pounds at once since it tends to cloud up the water. If I do it this way, it will take 2 days to get all of it in there. I know from experience that calcium gets extremely hot when you add it to a bucket of water so I'd like to broadcast it in the deep end instead unless there is a reason not to do it that way.
mknauss
27,086
Laughlin, NV
Add the acid. By the time you put that away and get the calcium, add that. By the time you walk back to get the salt, add that. Brush, swim whatever to mix and dissolve the salt and calcium. All of this with the pump running.
Reactions: gwtw
