Optimal pool filter pressure?
smooth2222
286
michigan
Just installed a VS pump,
What is the optimal pool filter pressure? As i can adjust the rpm to get any pressure i desire, so what is the optimal?
From what i been reading i,m seeing 5-15psi and 10-20psi? What is the optimal?
jblizzle
43,238
There is no optimal pressure. You want to run it at a low enough speed such that all of your equipment is working properly.
Doing so allows you to minimize your electrical usage.
chiefwej
3,517
Tucson
No optimal minimum. With a VS pump you can use a low speed for filtration and it will work fine. Many here run the pump at 1000rpm. There may be other reasons to run higher speeds though, like getting enough flow to make skimmers work, or it may take more flow for heaters (solar or gas) or for a SWG.
pooldv
Platinum Supporter
Moderator Emeritus
Aug 10, 2012
25,412
FL panhandle
There is no optimal filter pressure. It varies with all pools and plumbing situations. I run my VS pump at 1100 rpm and my filter pressure is 0. Filters are more efficient at lower flow rates.
jblizzle
43,238
You bump the speed up to where you get a higher reading and use that speed to determine when your filter pressure has gone up by 25%.
jblizzle
43,238
There is also really no point to run your pump for 24 hours. Even I have a low speed you should only need a handful of hours to have adequate circulation. Although you might want to run longer for other reasons.
pooldv
Platinum Supporter
Moderator Emeritus
Aug 10, 2012
25,412
FL panhandle
I run 24x7 in spring and fall when the trees are dropping lots of stuff in the pool to keep it skimmed and off the bottom since we live in the woods. Otherwise, I run at night when cooling the pool in mid-summer and during the day when heating the pool.
I check filter pressure at 2500 rpm.
