One Year Old Pump Locked Up!
CCarter59
3
Loudon, TN
Our pool guy installed a new pump in April of last year. He came to open for the season yesterday and found the pump locked up due to corrosion. Says the old housing must have caused a leak and due to the amount of corrosion, pump won’t be covered under warranty. Suggests buying another new pump and housing unit. Is this just bad luck or did he miss something in the installation?
jimmythegreek
789
Morris Cnty NJ
When u say he installed a new pump you mean he replaced just the motor onto the old pump body?
If so the seals should have been replaced they're cheap and it's cheap insurance overall
CCarter59
3
Loudon, TN
Yes, he replaced just the motor. Now he’s saying we need to replace the entire pump since the housing is older and was likely the problem. He’s a reliable guy but feel he dropped the ball on this repair last year.
borjis
2,762
Pacific NW
This seems kinda fishy. Doesn't make much sense. He should be covering the new motor in my opinion.
Sounds like poor workmanship.
JamesW
13,859
Most likely, the seal leaked and corroded the motor. If you rotate the shaft, it should break free fairly easily and the pump would work.
However, the seal is probably bad and the bearings in the motor will probably fail within the year.
If the service person felt that the front end of the pump was in poor condition, they should have recommended replacement.
Since they did the motor change only, the responsibility is theirs.
I would ask for a replacement under warranty.
If necessary, file a warranty claim with the motor manufacturer. Don't go into detail about what's wrong with the motor because you really don't know. Just document the replacement date and that the motor does not work now.
ajw22
5,411
Northern NJ
You tried to save some money by replacing just the motor versus the entire pump. Usually you win that bet and sometimes you lose.
Can the service person totally assess the condition of the rest of the pump and tell you how long it will last? Not really, it is a judgement call. It is not black or white he should have known.
You lost the bet on that motor replacement. An acceptable fix to me would be he replaces the pump and charges you his cost for the new pump. You get a new pump with manufacturers warrantee.
JamesW
13,859
If the pump needs to be replaced, I can see paying for a new pump and installation, but I would want credit for the original motor replacement, parts and labor.
The service person can return the motor for a new motor under warranty. So, they're not out anything.
In any case, it's the service person's responsibility to recommend a new pump instead of replacing just the motor if they feel like it's the better decision.
I would try rotating the shaft from the back. It will probably break free and work just fine.
If the motor just hums when power is applied, it might just need a new capacitor.
What exact pump and motor do you have?
Do you have a picture of the pump?
Pool_Medic
601
Bangor Maine
Easy to shoot the PG, but the owner might of balked at the cost of a new one so they went with the cheaper alternative. IMO warrant will not cover this nor should the PG be held responsible.
CCarter59
3
Loudon, TN
For the record, we weren’t told we needed anything other than a new motor last year. We are new pool owners, having bought a house with an existing pool, so we are very reliant on our pool guy for guidance. Had he said we needed to replace the pump, we would have done so.
Reactions: tstex
JamesW
13,859
Try rotating the shaft from the back to get it to break loose.
Turn off the power and turn the shaft clockwise with a wrench.
cfherrman
2,207
Hays, Kansas
If I was in your spot I would ask the pool guy why wasn't the whole pump replaced, was the seal replaced, why is the seal leaking after you touched it, why didn't you notice the seal leaking. I would ask for a big price reduction on a new pump as he in my opinion dropped the ball, either something was wrong with the pump end and he didn't catch it or he installed the seal wrong, both are his fault. If no price reduction, ok, see ya later dude good luck with your business.
Other Threads of Interest
