Omnilogic
Arik79
In The Industry
Mar 14, 2019
1
Mississauga
Just a question on setting speeds on a Tri-Star 950 VSP (previously the Eco-star). I wired the pump 230v as so and data cable properly 2 to 7 and 3 to 8. Set this pump as a feature run on a VSP (as it only controls a 3 sheers). The HUA is read and configured correctly.
The pump will power on and run full throttle only (VSP is selected and the LOW , MED , HIGH speeds are set). I even u wired the VSP via data and ran it in stand alone for a test and it won’t even change speeds either. Full throttle only. Any ideas ?
Thank you
Jimrahbe
14,467
Bedford, TX
A,
Sorry you have not yet received an answer... Let's see if we can get some of our Omnilogic guys to chime in...
