Omnilogic not toggling Hayward heater between pool and spa
sshap6
3
Boston MA
Hi,
Looking for some help here. We have an Omnilogic automation setup and a Hayward heater. We have a leisure USA pool/spa combo. The omnilogic app no longer toggles the heater between the pool and spa. We have to manually change it anytime we want to heat the spa. The app will, however raise/lower the heat of the pool or spa once it's been toggled manually. Any ideas on how to resolve this?
Thanks!
ajw22
29,140
Northern NJ
Pentair Intellichlor IC-60
Welcome to TFP.
Check the toggle switch on the bottom or side of your RETURN AND suction ACTUATOR that it is not in the OFF position.
Post pics of your equipment pad and valves.
ajw22
29,140
Northern NJ
Show me full pics of all your equipment and plumbing.
Show me IMG_0145 when in POOL mode and SPA mode.
sshap6
3
Boston MA
Here you go. 0151 is in Pool Mode. 0152 is Spa Mode
ajw22
29,140
Northern NJ
Also, I don't know why your suction valve in POOL mode is cracked open to pull water from your spa.
The handle should be aligned with the blue line to pull from the POOL skimmers only when in pool mode.
