Okay to run chlorine a little high?
Titan7
663
Fullerton, CA
Test results
FC- 6-7ppm
pH-7.5 7.8
TA 80
cya 65 ish
Ch-350
Salt 2900
Working to lower TA, adding acid once I hit 7.8 ph. Will check cya again.
Target for SAlt pool was. FC of 5ppm, okay running a little higher in the summer?
pooldv
Platinum Supporter
Moderator Emeritus
Aug 10, 2012
25,412
FL panhandle
Yes, a little more chlorine is always better than being too close to minimum. I have run my CYA at 80 and my FC 8-9, 12 if lots of people are swimming, the last couple of summers and my pool is much easier and more stable. After a bunch of swimming yesterday my FC unexpectedly dropped from 10 to 7 overnight. Did some varmints visit? I don't know. If I had been at target of 6 I would have been dangerously close to min of 4 or under it.
[FC/CYA][/FC/CYA]
