Hello all,
Looking to replace the following seals, o-rings & gaskets on my Hayward SP2300VSP Max-Flo VS pump, would you go with OEM or aftermarket?
I understand they're just rubber, but it's proper fit that I'm most concerned about with aftermarket.
I found what appear to be OEM replacements available on AMZN with recent prices listed:
Two-piece shaft seal (SPX2700SA) $15.99
Diffuser o-ring (SX220Z2) $11.87
Housing gasket (GMX600F) $14.66
Strainer cover o-ring (SPX2300Z4) $28.62
As for aftermarket, I've been referred to the following two "Go-Kits", GO 1 Kit for Hayward Max-Flo 1800/2800 & Hayward Max-Flo GO-Kit 32, so I'm a bit confused as to which seal kit is compatible with my SP2300VSP Max-Flo; Go-Kit 1, Go-Kit 32, some other??
I appreicate your feedback!
