OB Northern California (Roseville) Rehab / buried
mguzzy
2,207
OV, CA
I found the builder, but seems to have gone out of business awhile ago...
Now that is cool... Keep the plaque and add it to the remodel... heh heh...
I can't believe I'm just finding this one.. Howdy neighbor.. I'm just down the street from you.. just a stones throw down the ole SCB.
It looks like the bond beam is in good shape. and I bet the rest of the shell is decent as well. I don't see any cracks that would indicate the shell is compromised. I bet its build like a tank! Clean it out, fill it up and lets get to swimming!...well not quite. Some thoughts based on what I read over the last few pages....
-If you are looking for things to DIY.. chipping out is not that difficult.
-Are you going to keep it that deep? If so you might consider a bottom drain.. it helps circulate water from the deep end. If you change it to 6 ft deep, not so much.
-The consensus among most if get a robot these days. They are cheaper to operate and clean better.,, luckily the reliability is getting better to.
-I'll say it now.. plant the seed.. SWG
-Are you going to keep that shape? Now that you have it dug out and if the shell passes muster, it seems like a pretty cool arrangement to have.
Reactions: kimkats
Luckycoffin
24
Roseville, CA
Alright back at it again!!!!
Phase 2- finalize the remodel/design... See attachement
Need some input on design
Is the ....
Baja shelf - placement , size, etc...
Steps - size, placement, type, etc...
Benches- etc....
and finally what do you guys think of the wet bar stools ( yes or no - pros and cons)
Demo work is scheduled to begin this weekend - need to confirm design by Sunday
thoughts on built in Spa????? (would go next to Cabo shelf...
Next need advise on equipment; pool size about 25K
pump, filter, lights, controller, cleaner ( Salt or no salt)
requirements: Drain , Skimmer, 4 return lines, 2 lights (low voltage LED) autofill, pool sweep (suction type)
undecided : Spa and features (sheer decent)
And finally for now - surface finish - We are leaning towards quartz. What do you guys think
mguzzy
2,207
OV, CA
SWG-YES YES YES
Wet Bar stools-.. not a fan. I imagine they would get tangled up in your robot. I always thought they were a place where algae would hide when I went to pools that had them.. but thats just me
I like my built in spa.. sure its not efficient as a separate spa.. but I like my built in spa
Pool sweep- get a robot
I'm partial to waterfalls, sheer descents to me are boring.. too structured, I like the burbling randomness of a waterfall. I do have mine setup to run and different flows so I can have a raging Yosemite falls or dial it back to a more Feng Shui trickle.
Put a bench under your water feature.. for some reason my kids like sitting under the waterfall.
Equipment.. if you want automation, you'll need to get the same brand equipment or at least everything that will work together.
Did you use crayons in your plot plan? I like it!🖍🖍🖍
kimkats
46,345
Tallahassee, FL
Bar stools-are you thinking they will go up on a bench?
Bench on the end of the pool. I would not put one there. With it there you mess up the "swim lane". You cannot do a flip turn. I also worry about anyone jumping into the pool from that part of the pool. They may (will?) hit the bench if they are not careful.
I WOULD have a bench by the seating area BUT not all the way across like you have it now. A higher area to act as a step to get out of the pool to visit the seating area on that side of the pool would be a good features. I would do the bench where the barstools end AND have a small bench/step in the corner over there.
johig
Nice plans!
I don’t think you will regret a SWG. Definitely consider it.
We have a suction port for a pool sweep and have not used it once. Got a robot and never looked back. Seeing how much junk winds up in there (dust, dirt, sand, dead insects, leaves, etc.) I am very happy to not be sending that all straight to my filter. Especially because I have a cartridge filter that should not be backwashed.
Baja size and location looks great to me. I can’t quite tell what you are planning for step(s) down to the shelf, or the shelf depth, but I would recommend a step or two so that the maximum step down to the shelf is 6 to 8 inches high. This will give an easy access point.
I’m having trouble visualizing the bar stool arrangement but I agree With KitKats that you should think twice about the bench at the end. Maybe it will work for you, but deep end jumping and benches are a potentially dangerous combo, especially where kids are involved.
How much you care about a swim lane is a personal choice, but my pool builder advised me to keep one open and I’m glad I did.
A built in spa is great because spa season is way longer than pool season, unless you want to spend a lot of money heating a pool in winter/spring/fall.
I like my sheer descent but I try not to run it all the time. I’m sure it contributes to pH rise. Also, at high speed the water fall noise is actually loud enough to be annoying after a while. Whether it’s a waterfall or sheer descent, I recommend you have options to control the speed and turn it off.
For equipment, get automation and remote control if at all possible. I use Pentair ScreenLogic. It has quirks but I would not give up the convenience.
Good luck. I remember the decision-making phase of our build. It’s fun but also kind of exhausting!
Luckycoffin
24
Roseville, CA
Thank you all for the great feedback.
I did get a little carried away with the color pencils... Lol
I think I need to be walked of the ledge on this one. I'm thinking of taking on the plumbing project my self. I have gotten back a few quotes which seemed high ( based on scope of work in my opinion)
Conditions:
- pool decks removed
- pipes about 18" deep
Scope of work:
- update drain
- replace skimmer (10-15 pipe run)
- pool sweep (12 pipe run)
- 3 return lines ( 35-40 feet)
- 2 lights ( 12-15 runs)
Q1- $5000
Q2- $3800
Q3- $5500
DIY
- Use trencher to trace lines
- drill out and replace lines
- replace skimmer already dug out
- add second pool light
Cost
- trencher $180
- materials (pipe, glue, fittings) $600 ish
- time few days/ evenings
What do you guys think?
Also has anyone used S.R smith pool lux light kits?
kimkats
46,345
Tallahassee, FL
The cost to your body is MUCH higher than that. Yeah you may be able to pull it off but at what cost? When will you be able to do the work?
The amount of time it will take you doing it on your own will be long and drawn out.
There are times when it is best to work with your wallet instead of your back. It is up to you which way you want to go.
johig
Personally I would not attempt the plumbing. The thought does not appeal to me at all. The thing that would make me most nervous is that if anything goes wrong in the future with plumbing, the repairs may involve demolishing and replacing bits of your pool deck or other hardscape.
The main reasons I could see doing it myself would be:
- if I had experience and a high level of confidence.
- I was really interested in learning how, and motivated to research all the details to get it right.
- if I was really worried about the money.
I’m sure there are others who disagree. Good for you if you can do it. For me, this is one of those tasks where I would much rather write the check!
Reactions: kimkats
spd500
311
Houston, TX
It is really all up to you. I would probably do the plumbing myself because I know how to do it and I am used to that kind of labor. We are remodeling the second floor of our house right now and I am doing all of the work except the drywall. I could do that part too, but I hate drywall. Because i am doing the work it will take a month longer, we will save $15K, and i will know that it was done to my standards.
Desert Dog
206
Alpine, Ca
Do those quotes include placing and hooking up equipment? If so, I think they are good prices. A team of three experienced pool plumbers may have that knocked out in a day, two tops. Yours of course is a rehab and not new, I would think that would add to the difficulty. especially drilling the pool shell.
mguzzy
2,207
OV, CA
And pressure testing the lines too?! If that is included as well as the equipment pad work sound like a good deal to me. And I did all my own plumbing when I relocated my equipment pad.. Would I do it again, yes, only because I know how to do it. So its your call.
