Not seeing a chart on how much to put in to do various things??
jetskierg
21
Phoenix, Arizona
when I do a search i only get forums and not articles. I need to know how much soda ash to put in to raise ph and TA. I have read some of the chemical articles and i do not see anything about how much to put in or how to disperse. thx
jetskierg
21
Phoenix, Arizona
it says to put in 84 lbs of soda ash which sounds heavily inflated. I'm assuming Borate is the Total chlorine/Bromine reading, and CYA equals Stabilizer reading?? Is CH asking for the water hardness reading? If not, I do not see that it is asking for that. thx
mknauss
22,951
Laughlin, NV
What are you trying to adjust with soda ash? Post your test results.
The OTO for chlorine/bromine is not used. You do not have any bromine unless you have added it to your pool.
ajw22
11,627
Northern NJ
Borates is a separate chemical. If you have not added it to your water then it is 0.
Yes, you view the dot in the tube to measure it. Round up. If the dot disappears between 40 and 30 you call it 40.
Yes, CH is calcium. It is one of the TF-100 tests.
jetskierg
21
Phoenix, Arizona
raise the pH and TA. after my digits are in, it states add 1401 oz of soda ash. thats with pH of 4 and TA of 30. I know my water is WAY out of kilter. I bought some a&h super washing soda.
JamesW
16,945
What test kit do you have?
Your other thread say that you're using test strips. Test strips are not reliable and you should not trust them to give you accurate information.
What are all of the readings from a good test kit?
What is the history of the pool and the chemistry?
Your other thread says that you use tabs but the CYA is zero. The CYA won't be zero if you're using tabs. The CYA is probably super high.
Are you new to the pool or have you just not been testing the water?
JamesW
16,945
It would really help to get an accurate reading for the CYA. Do you have any way to get that?
You really need to get a decent test kit if you want to get the chemistry under control.
jetskierg
21
Phoenix, Arizona
All I can do is look at my test strip results. If CYA means Stabilizer then it seems to not even register. The beginning color of test strips is Low/0 and that is a washed out orangey/tan color, and mine comes out a bright yellow. Yellow isn't even on the color chart. (purple is the very high color) Say that it really is low, and pH is low. Wouldn't you put soda in it first? I am on my own with this pool and have to do what I can. thx
IceShadow
1,072
Milwaukee, WI
Without accurate measurements, you are going to be blindly dumping chems into the pool. If you are adjusting pH you need to at minimum know the current pH and total alkalinity.
Otherwise I guess you can keep adding a little at a time until you are satisfied....
