- Jul 21, 2013
- 21,260
- Plaster
- Pentair Intellichlor IC-60
I took advantage of 65 degree sunny weather in the NYC area and took a look at the water level in my closed pool. As I though, with the warm wet winter we have had so far, the water is almost up to the tile line. It had been drained a good 9” below the tile line.
I managed to drop my submersible pump onto a ledge in between the spa wall and pool cover and it is now draining.
If you are in the Northeast I suggest you take advantage of this great weather and check the water level under your pool cover.
