We just purchased the Costco Bestway Power Steel 22' x 12' x 48" Above Ground Pool Set. It will arrive this week. We have never owned a pool and I would truly appreciate if you can help me with some questions I have.
1- The location we will put the pool is concrete. But there are gaps between the concrete slabs. Do I need to fill those gaps before I place the pool? Any recommendation how?
2- I believe the set comes with a ground cover. Is the pvc ground cover enough on top of concrete or do I need other padding?
3- I read that the plastic melts into the metal pipes, and a lubricator is advised before sliding the pipes in, what type of lubricator I can use?
4- I read the cover doesn't fit on top, did anybody experienced that? What type of cover you would recommend?
5- I will take a water sample to a pool shop after I fill it, is there anything I should know before I go?
6- What type of maintenance would you recommend?
