We just bought a house last summer with a pool. The pool has an in-line chlorinator, so we had been using that for a while with tri-chlor tabs and everything was going fine. However, once we became aware of the CYA issue, we looked into non-stabilized tabs. We found some, but the new tabs quickly clogged up our chlorinator, which is a problem we never had with the stabilized tabs. We have switched to just using liquid chlorine for now, but I was wondering if this is an issue with all non-stanilized tabs, or if maybe it was the particular brand I had. Has anyone had success using non-stabilized tabs with an in-line chlorinator? If so, what brand? Can we use the tabs by placing them in the skimmer basket instead? If we do that, would we need to run the pump 24/7, or could we continue to run it on a schedule? Thank you!
