Hello there,
Shot in the dark here (mostly because I am not 100% sure what I should be asking), but I noticed this evening that our new (about a month old) filter gauge is reading 0 PSI when running the pool pump at 1200 RPM. I did also notice a few bubbles at the top of the filter basket (about 3 or 4, just sort of moving in place). When installing, the PB suggested we open the valve attached to the gauge to release any air, but I tried that tonight and nothing happened -- No water, no air. It's almost as if the water isn't filling the filter tank at all.
The pressure *does* increase, to a little less than 10, when increasing the pump to around 2000 RPM, but I don't like having it that high at night because you can hear it inside our son's bedroom.
Is 1200 RPM too low for our pump/filter? Could I have a suction side leak here? Should I even be concerned? This all came about after a breakdown in our Intelliconnect system. I am having to manually turn things off/on until it's fixed and noticed the pressure gauge this evening.
Appreciate any insight.
Thanks!
Thanks!
