I noticed my chlorine level is low so I looked at the panel on my Aqua Rite Salt Water Chlorine Generator and the power was off, which I have never seen. I turned the breaker off and on again, and the power came back on - for a few seconds, then turned off again. I tried it a 2nd time and the same thing happened. The pool pump is on and everything seems to be operating normally except for the Salt Water Chlorine Generator. I looked at the cell and it's clean. I'm not sure if I need an electrician or a pool equipment repair person, or what to try. Until it's fixed I can manually add chlorine - I have shock now.
