- Mar 17, 2021
- 50
- Plaster
- Jandy Truclear / Ei
Has anyone used No Mor Muriatic Acid instead of muriatic acid with a salt cell? Is it as good?
i was looking at pool stores that ship since my local store closed and we only have Leslie’s. And I saw that as an option for Muratic acid. I have only used Muratic acid so farOut of curiosity, what is your reason for wanting to use it?
thank youHome Depot carries Muriatic Acid in the lawn/garden center, usually on an end cap near the other pool chemicals.
Buy that - it's the least expensive and easiest to find. Shows ~265 cases in N Frisco store right now.
HDX 1 Gal. Muriatic Acid Balancer (2-Pack) 10031HDX - The Home Depot
HDX 1 Gal. Muriatic Acid (2-Pack) is a powerful pH reducer for your swimming pool. It comes ready to use, with no pre-mixing required. This fast-working chemical helps prevent scaling caused by calcium-basedwww.homedepot.com
Thank you. I used to always go to 1stop pool and spa but they sold to Leslie’sIn Frisco area Home Depot, Lowe's, Pinch-a-Penny, Ace Hardware or 1 Stop Pool & Spa to name a few, all carry Muriatic Acid.
I didn't know that….thanks, you saved me a trip!Thank you. I used to always go to 1stop pool and spa but they sold to Leslie’s
PaP in McKinney is more expensive than Leslie's fyi.I didn't know that….thanks, you saved me a trip!
Thanks for the tip I did not know that. Is all of there acid at leslies that strong or do you need to look for it?Here in Las Vegas only Leslie's or other pool stores are licensed to sell 31.45% Muriatic Acid. The big box stores can sell 14.5%. For the price because I can get more doses out of 31.45% I buy from Leslie's.
Several brands like the ones at the home centers stopped listing the %. The data safety sheet for the HD kind now says 10%-30% as a trade secret.Is all of there acid at leslies that strong or do you need to look for it?
If Leslie’s doesn’t have 31.45% in stock, the big box stores will be cheaper with their 14.5%. In the garden section of Lowes and Home Depot is where they keep their MA along with their pool supplies. The percentage strength is on the box.Is all of there acid at leslies that strong or do you need to look for it?
