My turbo cell T 15 does not appear to be producing chlorine. Salt level does not drop no detectible chlorine. I have a prologic control panel. This spring the chlorinator read high salt/amp. I noticed a solder spot on the back of the motherboard was gray and faded. I resoldered that and the error message went away. Since then there is no chlorine from the T cell. I replaced the T cell still no chlorine. The volts amps and salt level readings are all normal. I am stumped. Any help would be appreciated. I’m going to check fuses today but don’t suspect that’s the problem. Hayward Support was not helpful.
