I am helping a friend troubleshoot his pool heater (Jandy 400). His unit is getting a single flash LED light which indicates an air flow fault. After the unit shuts down the display indicates Fault- Check IGN Control. I checked the obvious signs like blockage (inlet and outlet). Put meter across air flow switch and water pressure switch to ensure contacts were being made up during startup, checked continuity on ignitor which was fine. I can feel air flow in the discharge but not sure what is sufficient but if air flow switch contact is closing I assume I have sufficient air flow. I then pulled the leads going to the ignitor and put a meter across the module outputs and I have no juice going to the ignitor after the unit starts and goes thru it’s purge sequence. I then thought it might be something in the Fenwal ignitor module so I replaced it, still getting the same error code and results. Is there something else I should be checking or could it be something wrong on the Universal Controller Power Interface Board. Any thoughts or help would be greatly appreciated.
