I'm currently in the middle of a no drain water exchange, but my subpump is pushing out water a lot faster than my hose is filling. Subpump rate is 20 gal a minute fill rate with my hose is only 6gal minute. I don't want my water level to get too low because it's going to be nearly 100 degrees tomorrow in AZ and I'm concerned about the plaster. Should i let it drain down a few inches then turn it off until the hose can catch up? How do i figure out how long i need to run this to exchange enough water to lower my CH?
