No CYA and lots of Algae
Lroberts32
Active member
May 17, 2015
38
Washington il
Opened our pool today any have algae. Bad. Need advice on when to add CYA since it’s at zero.
FC 0
CC 0
PH 7.3
TA 30
CH 40
Temp 55
Currently scooping worms from pool floor and brushing algae. When do we add CYA. Before adding chlorine? Going to slam tomorrow and need help with the order of adding
Texas Splash
Keep doing that as much of that as you can first. The less junk the better. Vacuum to waste might help as well. Once you're done with that, don't add CYA yet. Increase the FC to 10 and re-test in 10 min. If it crashed below 5, add bleach again and re-test in 10 min. Repeat that process until the FC begins to hold closer to 10, or at least over 5 for ten minutes. Only after the FC begins to hold should you add stabilizer for a CYA goal of 30. Then increase the FC to 12. Then you are officially SLAMming.
Lroberts32
Active member
May 17, 2015
38
Washington il
Thank u!
Reactions: Texas Splash
Msch99
387
Verona, MO
So if cya is zero, wouldn't it make sense to wait to add cya until pool cleared up at least somewhat? FC slam rate would be lower... just curious.
johntniman
141
Las Vegas
Since you have an outdoor pool, you'll need some CYA to protect the chlorine from the sun during the majority of the SLAM process. Otherwise it will burn off extremely rapidly. What TexasSplash is saying is to wait until the FC holds for the short interval where it's not all being used up within 10 minutes before adding CYA. After that point you can raise the CYA to an intermediate amount, like 30. After the SLAM is over you might raise the CYA to a more permanent amount, like 50. CYA 30 seems to be a sweet-spot, where you don't need too much chlorine during SLAM to overcome the CYA, but the CYA isn't so low that the sun eats it before it kills the organics in your pool.
mknauss
22,749
Laughlin, NV
A minimum of 30 ppm CYA is needed to protect the chlorine from UV destruction in minutes.
The process Pat stated above is to check for ammonia in the water. With a 0 CC it is not likely, but possible.
Reactions: Msch99
jblizzle
43,260
That just means that you have no ammonia, it does not mean that you necessarily have CYA in the water.
Now you want to add CYA to target about 30ppm and follow the SLAM Process process.
