No chlorine and free chlorine at zero
zea3
12,466
Houston, Texas
How much chlorine have you added, how often have you added chlorine, and could you please post the most current set of test results you have?
YippeeSkippy
13,500
Evans, Georgia
"Pool Professional" is kinda funny. Pool store tests are often more wrong than right. Having your own quality test kit puts you in control of your pool. No one wants to do a better job of testing than you. Pool stores often just test to sell a product or three.....
Maddie :flower:
duraleigh
Admin
Platinum Supporter
In The Industry
Apr 1, 2007
33,853
everything perfect but zero chlorine what causes this.
To take a stab at your original question, you probably have algae in your pool that you can't see. Left alone, this algae will bloom and turn your pool green.
Everything posted above is true. Pool Stores are horrible and we encourage you to stay out of them.
Please read "The "ABC's of Pool Water Chemistry" up in Pool School and please consider doing your own testing and learning the methods we teach.
Candler98
8
Greenville SC
What algaecide do you recommend
mknauss
29,879
Laughlin, NV
TFPC does not recommend algaecide. And algaecide does nothing to eliminate algae. It can prevent it, but many times with unwanted side effects.
To defeat algae, we use SLAM Process. You need a proper test kit to follow the process.
Shirker
552
Athens, GA - USA
@Candler98 , follow the SLAM link posted above. The methods we use don't work well with pool store advise. Essentially you will need to acquire your own test kit and do your own testing. Once you have one of the recommended test kits, the experts in the community can help you get your water perfect and chemical expenses way down.
