Nicheless lights
Steve7124
8
Austin, Texas
Moved from here.
Hello! Ok, bit of a tangent here. I need to replace my pool lights and after a great deal of research (everyone say, just need to unscrew one screw to take the light out) I have determined I must have nichless lights in my pool (installed in 2011). I managed to unscrew the faceplate to the light, but have no idea how to get the actual light out. Are they all the same and is it just a quarter turn to unlock it, or is there some other secret to get the light out to replace it? Thanks for any help you can provide.
mknauss
23,542
Laughlin, NV
I have Pentair GloBrite lights. To remove them, you first isolate the power from them, disconnect the wiring at the JBox, tie a pull string to the wiring, then pull the light out of pool. The cord and light are one unit. You use the pull cord to pull the new light/cord assembly into place.
You need to determine what brand of light they are. Then get with InyoPools to determine what you can replace them with.
Steve7124
8
Austin, Texas
Thanks for your reply, however to get the light removed do you just pull it out or does it unscrew. My light does not twist easily so I don't want to break something trying to take it out the wrong way.
santacruzpool
709
Santa Cruz, CA
I know that there is usually a tool to match each different brand/type of of nicheless lights. The older Savi Jandy lights had a 2 prong pin tool, the latest water cooled Jandy ones have a new star pattern tool to screw them in which should be a little easier. The Pentair Nicheless lights have a special tool as well - below is a screen shot from the Pentair manual showing a drawing of the tool to give you an idea.
Reactions: Steve7124
mknauss
23,542
Laughlin, NV
After disconnecting the wiring from the JBox, you pull the light out. Be sure you use a pull string tied to the wire of the old light. You do need to use a tool to unlatch the light from the housing.
Steve7124
8
Austin, Texas
Thank you. Of course I Don t know the brand I have so don't know which tool to get but at least I know they all unscrew from the wall fitting. Once I get the light out I will know what brand to replace it with as well as the appropriate tool.
mknauss
23,542
Laughlin, NV
Once the water warms up you can probably use something other than the specific tool to get them out. Something with a blunt end. Might need a couple of them.
santacruzpool
709
Santa Cruz, CA
Depending on the type of tool you need, our installer, who replaced our last set of lights, said he used needle nose pliers when the special tool wasn't available for the older 2 pin style Jandy/Savi lights...he said it was a pain to do when they were tight. Even with him using the proper tool our fittings are now a bit scratched up - not sure how that happened, but it doesn't really matter - just more info for you...
Steve7124
8
Austin, Texas
I found that my lights have a plastic ring that screws in and appears to take a special 4 pin too. I was able to unscrew that ring but the light remains in there and does not look like it has any holes for a tool to hold on to. I was thinking I would use channel locks with a rag to try to unscrew the light...
mknauss
23,542
Laughlin, NV
The light will not really 'unscrew'. At most it is a partial turn to latch it in. Though with the ring you removed, it may not even have that.
Since it needs to be changed, I would suggest disconnecting the cable at the JBox and see if the light can be pulled out.
