I am a first time pool owner here. I went to Wal-Mart and found a, 18’ x 48” Coleman pool. Though I probably could have done better, the ground is fairly level. It appears to be below the 2” out of level threshold I have heard of. I measured the water depth this morning and the biggest difference is about 2 inches.
My main concern is the higher side. There is evidence the support leg on that end has been pushed back a little due to the weight of the water pushing on it. Also, the leg next to it is slightly crooked. I also didn’t end up putting pavers under the legs because I was worried the liner would brush up against the pavers and there would be a puncture risk. If I could do it all over again, I would have spent a little more time digging out the high side and I would have put pavers under the legs flush with the ground level.
Do you think, based on the pictures, it looks satisfactory, or is there something alarming that would indicate a reinstall would be in order here? Thanks for your help.
