Newbie Build - 27' Round AGP - Help Me build This
stringer77
107
Central FL
Awesome thanks. I dug out a great spot for equipment pad.
Having a major ant problem. They are popping up everywhere and I noticed while covering up ant piles and stomping inside pool, the sand keeps falling into the ground like sand through an hourglass. I imagine this will create depressions in pool bottom, trapping debris and looking like Crud.
best fix?
kimkats
44,786
Tallahassee, FL
Play sand and mush it down good trying to make sure you fill in all of their tunnels...........oh and get some liquid ant killer and soak the are with it and let it sit for a while. See if that gets rid of them for good.
stringer77
107
Central FL
Hooray for trenching day! ⚒
Looking forward to "bonding" with my pool tomorrow, haven't had a whole lot of time to work on it. Got trenching done for electric, and bonding. Electric is all roughed in with 3/4 conduit, extra tough cement, and 12/2 underground wire 24" deep, bonding trench 12" deep. I will pick up a disconnect box next time im out. Can I drop pvc pool plumbing and bonding wire in same hole?
stringer77
107
Central FL
ok thanks i will fill in trench a bit to bury at 6"
How to I run 1.5" pvc to this Crud?? 1.5" pvc will not slip onto skimmer on that wide part, which is too big. do i need more parts??
thanks
Newdude
2,443
NY
stringer77
107
Central FL
well upon closer inspection, the 1.5" pvc seems to fit decent around the skimmer (i mistakenly grabbed something 2"), though it has a barb as pictured and not 100% positive it should mate together. The return has 4 smaller barbs/ribs and when fitted with the 1.5" pvc it is very loose, like 1/8" or so too small. Doesn't seem right that it does not fit together well, need to hold off until someone can elaborate on this. Thanks.
Mdragger88
309
Hernando, Ms
Its made to fit push on hoses with hose clamps - not really sure how to mate that with pvc. Whats the inside diameter? Maybe use a small piece of pvc inside then convert to your desired size if u intend to use unions & valves etc.
Newdude
2,443
NY
This one on the PVC :
This sprinkler pipe fitting screwed into it, but the pvc version. HD/Lowes has them i just cant find them
Then use a push on hose with clamps on either side.
stringer77
107
Central FL
thank you i think this is the right direction. its just that that nibco is DWV only, not meant for pressure so i have to find something else.
Newdude
2,443
NY
They had both. The website wasnt liking me tonight. Of course your local HD will only have 3 of the 4 pieces you need, so maybe go to the plubling supply place. Bring pics and whatever pieces you can and they will set you up.
