New user introduction
richwyoung
1
Danville, CA
Hi, I live in Danville CA. Have a 20,000 gal salt pool built in 2006. Has a number of issues based on age plus the deck around the pool is sinking causing leaks in the related pipes. I had the solder issue DJConn described "The issue was caused by a broken/weak solder point on the K1 relay." and desoldering fixed the issue. Thank you DJConn!
The other issue I have is the valve next to the pump leaks in air.
Rocket J Squirrel
992
Alamo, CA
Howdy, neighbor! For best results, create a signature with a list of your equipment (see mine for a verbose example) and post photos showing your issues.
