First pool opening and did a water test. I plugged it all into the pool math app so I was planning on just following those directions but thought I would post here as well in case there are any other suggestions. I have a fiberglass pool about 17500 gallons including spa. FYI pool company opened and added some shock to clear up pool initially but it has been a couple weeks since then. I have a SWG and 10 bags of salt but it’s been too cold for that to work yet.
Results
CH: 175 - says to add 16lbs calcium chloride
CYA: 0 - says to add 177oz dry stabilizer
FC: 0 - says to add 74 oz of 6% bleach
PH: 7.8
TA: 90
Do the amounts sound right? Does it matter how to add and which first? Space it out? Also any recommendation on pool pump settings? I have a VSP. I’m planning to pick up some liquid chlorine and dry stabilizer from Walmart today and then go to pool store for MA. With COVID-19 I’m obviously trying to limit my trips out so any advice on any other supplies I should pick up for routine summer maintenance? Pool company was saying all I need is a 25lb tub of shock and just add as needed but I realize opinions differ and I’d rather use the advice of this forum. You have all been excellent so far with your help and I thank you!
*Edit - I should add that I noticed some slight accumulation of green/brown on the sides and steps which is probably the start of algae. Do I start with a SLAM?
Results
PH: 7.8
TA: 90
