New to TFP
Fitzpadw
1
Williamsburg, Ohio
Hello we recently bought a home and it had a 21'X 41' Oval above ground pool. The pool doesn't seem to have been taken care of the best. It was not covered for winter and upon looking at it appears to have a reddish gunk all over the bottom of it. The pool is at least 3 years old according to the neighbors. What are my first steps? Should I drain and try to refill, or test the water and see if I can win the battle using SLAM?
mknauss
22,729
Laughlin, NV
Welcome to the forum!
If it holds water, then all it will take is patience, work, and chlorine to get it back working.
First step would be to check out the equipment and see if it runs. Next would be to order a TF-100 and test the water. Start netting out all the solids you can. Then when you get your kit, test the water and post the results here.
I suggest you read ABC's of Pool Water Chemistry and consider reviewing the entire Pool School eBook.
setsailsoon
1,754
Stuart/FL
Fitz,
Welcome aboard! Marty is right on the money, I've watched from afar as he helps people like you get sparkling pools in no time! Just follow his advice carefully and ask all questions. You'll be on autopilot before you know it!
Chris
