I tested my water this morning because I've been trying to get levels in shape. The water looks kind of hazy when looking across the pool underwater, from outside the pool looking down it looks fine (but it is only 30").
The pH is 7.2, while the alkalinity is 160...which seems weird to have a low pH and high alkalinity (especially since I haven't added anything to adjust either since I filled the pool). Otherwise CYA is 40, FC is 5, and my kit doesn't test calcium hardness but with my vinyl pool I'm not too concerned about that.
How can I fix the pH and alkalinity of the pool? I'm worried that driving pH down to lower the alkalinity will get the pH so low that it will cause problems. I'm considering aerating the water to drive the pH up without affecting the alkalinity then adding acid to lower both. Is this my best option?
Not sure if my signature is showing so I'll include those stats:
Intex 13' easy set vinyl pool
Intex Krystal klear pump with cartridge filter(came with pool)
Taylor - K1004 Test Kit (reluctant to spend more on a test kit than I did on the pool...)
