I am a relatively new pool owner and have been trying to understand how my system works. Certainly, this is my first IFCS. From what I gather, I have a combo A&A/Paramount system to deal with my Pool/Spa combo with grotto. After getting my water tested, I decided to do a fresh fill (dissolved solids above 5000 ppm) and take the time to pressure wash the side. I also removed all (48) gamma 4 heads. I disassembled them, acid washed the parts and replaced both o-rings on each head. I know I'll get asked about pressure, set up, etc. but for now I just have some broad questions:
1. The Gamma 4s have adjustable sized orifices/nozzles. In general, how should they be set up: small nozzles for steps/shallow areas, spas, grotto and large for deep center of the pool areas? or vice versa?
2. I've read that the those closest to the main drains/center of the pool are fixed? How are these distinguished? I read this after I had removed and replaced them, but I don't recall any being different. There was one that had a gray versus light blue plastic ring that rode with the spring, but I just thought this was aesthetics.
3. My pressure at the cleaner valve doesn't get higher than 10psi and falls when transitioning between zones to 0-2 psi. This seems low. This is even with my heater bypass open and a thorough cleaning of the intellichlor cell and filters. Pressure at the filter (cartridge) is around 27psi. What can cause the low pressure? a blockage in the return line? The gear sets for the paramount and A&A valves are fine/new. No leaks at the o-rings (I've replaced and lubed them).
Thank you.
Chris
Thank you.
Chris
